Fastrider303
02 rxdi I hook water to the rear inlet at the jet pump and start it, no leaks. I put the ski in the water and start it and it is pumping water out from in-between the flywheel and the bracket. (See pics) it doesn't seem to be coming out at the carbon seal or pressure ring more of behind the flywheel as it's running only. And all the repair shops are booked for weeks please help! Thank you!
