rgardner928
So I decided to upgrade my plastic pumps to the bronze. When I received my bronze pumps the other day I also removed all the bearings inside and replace them with brand new ones. I also removed the wear ring and put a new one in also. So I literally have a used Mint Condition bronze pump with all new bearings and wear ring. I went to install the pump shaft to the impeller and when tighten it down I tighten it down tight, just as it was on the plastic pumps.
Side comment: On my plastic pumps I had to use a breaker bar to get the shaft and impeller loose. I did not use a breaker bar to tight it on the new pump.
BUT... now the pump is extremely hard to spin freely by hand. If I slightly loosen it a little, it spins freely by hand and when I stop spinning it..it keeps spinning. But when tightened all the way. I had to use force to spin it and it doesn't keep spinning when I stop spinning.
My question..How right do I want it?
