Proper Engine Break-in Procedures for Jet Skis
JoeZ
Administrator
ADMINISTRATOR
New jet-ski buyers often have the first impulse of jumping on and hitting the throttle to enjoy their new equipment. However, to assure engine longevity and adequate performance for the life of your jet-ski engine, a proper break in period is required. Here are some tips that will assure that your new jet-ski will last for years at the performance level intended by the manufacturer. Always refer to the owner’s manual for brand-specific break-in period instructions. These break-in instructions are applicable to all jet-ski models except for 4 stroke models.
None of the jet-ski engine break-in steps can be done with the jet-ski out of the water. This condition applies to all models of jet-skis. Jet-ski engines that are improperly broken in due to negligence or by attempting to break them in out of the water can experience loss of power, frequent shut-offs, reduced performance, piston ring failure, and even piston seizure.
DI model jet-skis should not have any oil added to their fuel tanks.
For jet-skis that utilize an oil and fuel pre-mix system, the oil to fuel ratio should be enriched to a ratio of 32:1 for the first ten gallons of gas that is run. If the jet-ski is equipped with an oil injection system, then a 50:1 ratio of fuel to oil is recommended to be run through for the first ten gallons.
Upon initial startup, let the jet-ski idle for ten minutes to allow the engine to warm up and to allow oil to permeate internal gaskets and engine components. During the initial ten gallons of fuel being run through the jet-ski, the jet-ski should never be operated at full throttle. Doing so can potential cause damage to piston rings, pistons, and engine cylinder walls.
Begin cycling the throttle from idle up to 20% capacity and back down to idle for a full half hour while riding. Bring the jet-ski back and shut off the engine to allow it cool for at least half an hour.
Restart the jet-ski and bring the throttle to 50% capacity for a full half hour while riding. Bring the jet-ski back and shut off the engine to allow it to cool for at least half an hour.
Restart the jet-ski and bring the throttle to 90% capacity for a full half hour while riding. Bring the jet-ski back and shut off the engine to allow it to cool for at least half and hour. Repeat the process of riding the jet-ski at 90% capacity for half an hour and letting it cool for half an hour until all ten gallons of fuel are gone.
Never hold the throttle at a static level for more than a few seconds – it is important to cycle the throttle as much as possible during the engine break in period.
After the first ten gallons have been depleted, replace the spark plugs in the jet-ski with new plugs. Restart the jet ski and operate it as you normally would for the entire second tank of gas without bringing the throttle to 100% capacity for more than five seconds at a time.
Once the second tank of gas has been depleted, your jet-ski is broken in and you may ride it to its capacity.
I posted about my 01 GTI in the trouble shooting section but we bought a brand new GTI 155 SE yesterday. What is the break-in procedure for the four strokes? I'm going to the lake tomorrow and I don't want to have two expensive canoes. :(
Warming the engine up before gunning it, is a safe bet.
And Im not sure but do you get a learning key with those new ones.
If so leave it in learn mode for a few outings. Then switch over to full mode after you've used it a good few times.
But warming the engine up is a good bet.
Hope you have fun on it, you lucky so and so.:p:D
the short version for 4 strokes:
Break in.
Before each ride, do a visual inspection of Oil level, all hoses an for any loose clamps, brackets etc.
Warm up the engine totally first(in water) (off plane for 2-3 minutes) they warm up fast
Take it easy for the first hr, no more than 4000-5000 rpm.
Vary throttle for first two hrs, no more than 5000 rpm. Don't stay at one rpm for long periods. Only use 66% max throttle.
Let ski completly cool, down then repeat (this destresses the block).
After 3-4 hrs, short bursts of WOT are good, but don't go to top speed, just accelerate, then back off to 5000 rpm then repeat.
After 6 hrs, go to WOT for no more than 10 seconds.
After 7 hrs, your pretty much all done, ride it as you like but just refrain from long term WOT runs (more than 30 seconds)
10 hrs, change the oil.
As for the learning key, NO, use the normal key.
If the growling noise is between 4500 and 5000 rpm, its normal.
We used the learning key for all of maybe 1 hour or less... after that we used the normal key. Other then that, all of what Joe said pretty much summs up what my owners manual says for my 2005 RXT
