SaltyBones
Had skis out last two days and they ran great. Went out today and when throttling up on one of the skis, it misses. Still seems to have good/full power, but it's like it's missing or something. This happens the whole way through the throttle.
Could this be a fuel (bad gas/dirty carb) issue, or something with the drive (impeller/carbon seal) issue?
It has a new wear ring & when I looked under the ski the impeller looks fine with no chunks out of it or bent blades and nothing wrapped around the shaft. From what I can see the wear ring still looks fine and the ski does not appear to be taking on any water either. There's always a couple small bit in there (always has been...not even enough to have more than a few drops come out the drain plug). Oh...I do see light between the blades and the ring, but not much...idk if that's normal?
