If you go with all Genuine Mikuni parts Needle seat and spring... I have found the pop-off will be around 37PSI. My skis run best at that Pop-Off Pressure. The pop-off recommended range is around 23-38psi. Lower pop-off pressure I have found makes the skis run on the rich side regarding fuel. The manual should state proper pressures. Hope this helps. Good Luck.
