Hi guys, I put new Mikuni Carb kits in my 1994 GTX and after reinstalling them it's flooding out heavily. Upon first attempted startup it ran for maybe 15 seconds but it was rough. It continued to foul plugs after that and when I say foul I mean soaked in fuel. I messed with it so long that my battery died so I charged the battery overnight. In the morning I reinstalled the battery, took the plugs out and turned the engine over a few times to get any excess gas out. A lot of gas came out I mean like a couple cups of gas blew out of the heads. Is that my needle not seated right? Note that I did not replace the needles. One of them had a little bit of a ring wore into it very slight and the other one looked okay. I did not test pop off as I don't have the tool for it. Also I never really messed with the jets I just blew them out with carb cleaner and made sure they were clear. I did however take the low idle adjuster out and put a new seal on it on both carbs put it back in and then backed them out one and a quarter turn. I bought this ski off a guy that had already replaced all the fuel lines. It was stalling out at higher speeds so after reading a bunch of forums I thought it might be the smallfuel filters in the carbs.turns out he must have replaced the easy carb but the one that's hard to get to the one I had actually removed was 3/4 clogged up. So I replaced both filters, gaskets, diaphragms, the clear round plastic discs, seals on needles but that's it, used old needles, springs, levers.
