Hello Everyone- I am new to the world of PWC's. I am tech inclined and savy as I have spent much time around boats and dirt bikes. But these sea doo engines prove to be a little bit different.
Here is what I need help with
I recently bought a 2000 Sea Doo GTX. It is having a few problems. The red light on the dash is blinking and it says low fuel so I filled the tank up. The light still flashes and the display says low fuel. I think i have figured out my sending unit is bad.
On another note the ski will not fire. the engine cranks. I changed the plugs and cranked the engine for a while and removed the plugs. Dry as a bone.
I removed the filter in the front of the ski that is located downstream of the fuel selector valve. it has fuel in it. My question is how can i confirm I am not getting fuel. Obviously its getting fuel to the filter how can i see if its getting to the carb or to the intake?
A little different than on my bikes and boats that are either gravity fed, primer bulbs, or electronic fuel pumps.
It seems this pulls fuel off of crankcase vacuum.
One more question if i were to remove plugs and put premix in the cylinder and try to fire it would that be okay? My logic is if it fires on that then runs out of gas a few seconds later it is in fact true I am not getting fuel. The carbs seem to be difficult to get to because i have to remove exhaust and intake manifolds so i was hoping there was a way to confirm I am not getting fuel before removing so many things.
Please help a newbie out!!
