i have a 90 seadoo 587 yellow motor. i can’t get it to run right
it starts right up and idles fine as soon as you hit the throttle it wants to die
have rebuilt the carb with a new carb kit
it’s an aftermarket carb with a pulse pump built in. have tried it with carb pump and mechanical pump in the hull. no difference
swapped the carb with my perfectly running 587 and it does the same exhaust thing. so it isnt the carb figured fuel lines but i ran the in line straight from a gas can to the carb using the pulse line on the carb. no difference.
will run and rev fine with starting fluid
compression tested at 150 both cylinders strong
ANY IDEAS? pull the plug and can tell it’s not getting enough gas. no leaks
