Anyone with a 2000 speedster if you could do me a favor and take some pics of your steering column. A video of it moving left to right would really be helpful. I am having to replace the gearbox the steering wheel hooks onto and i want to make sure it matches up correctly. there are some different ways you can put the stop block in and different ways and adjustments. I had an issue where i could move the steering wheel from center it took 90 degrees to go full left turn and 180 degrees to go full right. i think someone messed with it before i bought it so i want to check a default config and make sure it is put in the correct way. Thanks a ton in advance for any help.
