Optimax M2 Submerged
Hi everyone, not sure how it happened but I found the back end of my Sea-doo Utopia submerged in fresh water. Can assume the engine is completely ruined? Any suggestions? I can't tell you how upsetting this is.
How long under? Fresh water? May be a survivor.
Get the plugs out. Turn engine over with socket on flywheel nut. Then- New battery. Crank with WOT. Plugs back in. Fresh gas or separate supply. Try to get it running. Drive it if you can. The plan is to get out most of the water. Then running, get it hot to get out the rest of the water.
