xlonewolf1967
I'm working on a friends 2001 sea doo gti with a 720 motor. someone who worked on it before him put in an SBT high torque starter for a 787. know its from a 787 because it has threads on the starter its self where as the 720 is threaded into the flywheel housing. and when they installed it they stripped out the hole in the flywheel housing on the bottom. so I pulled the motor and drilled it straight through. (nice and straight and true to the hole) and used a longer bolt and a nylock bolt on the back side.
ok heres where the fun begins. I installed the correct starter and it seated true in the hole no problems, got it all bolted up nice and tight and put power to it and it just binds in the flywheel and barely spins the motor with the plugs out. the motor spins freely by hand with no plugs in so its not seized. I tried 3 starters all of which start my 95 xp 720 motor with ease with the plugs installed. the teeth on the flywheel are 99.9% good and the flywheel runs true and not bent. I cross referenced the part numbers for my 95 xp starter to a starter for the 2001 gti and they are the same.
I am truly at a loss here....:facepalm:
