I just noticed the other day that the oil is leaking out of the oil tank. On the bottom of the tank there is some kind of adapter with 2 oil lines coming off of it. Is there an o-ring or a gasket that goes between that adapter and the tank that needs to be replaced??
yup... it has a rubber grommet that goes around the fitting... my gtx was leakin too i replaced it were all good now... there only a few bucks... look under the parts section at the top of the page buy what you need!!!
had the same problem, however there was a hairline crack about a half inch long at the hole on the bottom of the tank, he got a new oil tank and gromet.....
i will double check the tank and see if there is any cracks at all. I will be draining the oil and take the tank out on friday, i will keep you updated. thanks for the info. guys
if its cracked....save your money clean it out really really good and super glue the crack.... anyboty thats always working on different crap around the house knows super glue WILL melt plastic.... so put it on the crack and smear it around... adios crack
I had a similar problem , the bottom grommets on the oil tank were dripping. I pulled the tank , cleaned it out real good , pulled the grommets , used denatured alcohol on the holes and grommets and a really thin layer of black RTV going back together. Its sealed up tight now , no drips.
Good Luck !
