Dan Beaulieu
hi guys, I have a 2004 sportster 150 4-tec 155hp and over time an oil leak has developed between the bearing/bellow and the carbon seal sealing ring. i have changed the o rings in the bearing that is inside the bellow and also changed the o rings in the sealing ring. Then i took the boat out and the leak is still present. She leaks out about a half a gallon of oil per day. =( Is there anyone here that has ever seen this problem??? here is a pic
of the leak
of the leak
