Mark the oil tank at the beginning of each season, mix some premix to give extra oil for the first half hour while watching the tank to see it drop - those little lines fail as mentioned and they also get a gel effect if you mix oil as in not knowing what the previous owner used, if you are in this predicament drain the whole tank and fill with what you can get locally and stick with it, use premix while this oil works it way thru the system 5-8 gallons at a time, when you verify the system is drinking just add gas and go.
