Hi, I am new to Seadoo but I use to build 256 Rotax motorcycle motorcycle road race engines so have 2T engine experience. I bought a Seadoo 2003 800 GTX Fi with a problem of cases filling with oil. It had sat for 2 years. Have now stripped the engine and inspected. Because I have no manual nor experience of these engines, sorry. The balancer shaft end drive seems to be lubricated by the oil/fuel charge ? and the center worm rotary valve drive seems to be lubricated by oil, not sure whether this is a closed oil cavity or uses the 2T oil ? The engine has had a recent crank and the inner seals were not silicon sealed and was showing signs of spinning in the cases, which would explain how the cases have filed with oil. so I am hoping with the seals sealed to the cases the crank cases will not fill up again. because I did not remove the engine I am unsure of pipe routing. Can somebody tell me if the RV gear drive cavity is sealed or does it use the 2T oil ? hopefully it will be a simple fix ? Any advice gratefully received, Thank you. SP
