Hey everyone,
This is my first post here as I just bought a non running 1991 Sea Doo GT with the 587 Yellow engine. It had a locked up engine from sitting without fogging oil but I got that fixed and the ski is now running. There are a few issues that are preventing it from running ideally and wanted to ask the folks here to see if there's anything I should look at other than what is listed below.
#1. The engine will bog down and not run smoothly when it is first started in the water. It will do this for a while (maybe 10-20 min) then run just fine. Having no idea when the last time the fuel system was even touched on this, I plan on going through all of the lines, filters, and doing a carb rebuild. Are there any recommendations for carb kits? I want something that's good quality and the ones I see on amazon for $15 seem a little to cheap to be any good. Any recommendations at other things to look at fuel system wise?
#2. I noticed some 2 stroke oil on the engine mounts after running. Enough to make me look for any broken or loose lines. I found very thin rubber line on the intake side of the engine below/next to the carbs that was cracked and leaking oil. I plan on replacing it and going through the all the oil lines and replacing whatever needs to be replaced, along with the oil filter. Do the oil pumps ever go bad on these? Do I need to take the injection system apart and clean it or should I just replace the lines and filter?
#3. There seems to be a lot of noise coming from the jet area. The sound is high pitched and may be normal but I'm not sure. I have checked the jet pump oil ,which was full, and the metal collar that is on the PTO shaft, right before it passes through the hull has plenty of grease. Is it worth removing the whole jet assembly and checking bearings for wear or is this normal?
I'm sure I will have more questions in the future. I have a lot of experience working on small engines and have an automotive engineering degree but 2 strokes are not really in my wheelhouse.
Thanks in advance!
Thanks in advance!
