My 2000 SEADOO RX Millenium Edition Specs
jmeeder
Here are my specs, tell me what you guys think and know about this ski. Thanks in advance.
Manufacturer: Sea-Doo
Year: 2000
Model: RX
Vehicle Type: Performance
Color: Silver
Price: $2500.00 with trailer included and cover
Hours: 25
Engine: Two-stroke, twin-cylinder Rotax(TM) Orbital Direct Injection, R.A.V.E(TM) exhaust
Displacement: 951cc
Bore x Stroke: 88mm x 78.2mm
Compression Ratio: 6.1:1
Carburetion: (2) Automotive Throttle Body 46mm
Ignition: Digital Inductive
Transmission: Direct drive, forward/neutral/reverse
Pump: Axial flow, single stage, large hub
Impeller: Stainless steel
Lubrication: Variable Rate Oil Injection
Battery: 12-volt
Height: 41" (104cm)
Length: 112.3" (285cm)
Width: 47" (120cm)
Dry Weight: 606 lbs. (275kgs)
Seating: 1 or 2
Oil Capacity: 1.6 gal. (6L)
Fuel Capacity: 15.0 gal. (56.5L)
Storage: 10.6 gal. (40.3L)
