nitrosport_5
Hi, I recently purchased a set of bni 40 carbs used. They were on a 96 gsx. I am cleaning them up to use in a buggy with a skidoo engine and I want to verify the fuel lines are correct. I have a set of bni 38s on my other buggy and the bottom port on each carb is hooked together and the top ports are the returns. On the 40s, the top port on the pto carb went to the bottom of the mag carb, and the bottom of the pto and top of mag were returns. What way is the correct way? I had thought the 40 and 38 were the same besides the size of the throat. My 38s seem to work great the way they are set up. This iis why iI want to verify what way is correct or if it even makes a difference. Thanks iin advance
