Manual trim setup help
wtoll
Hi my vts trim motor doesn't work any more and I was wondering if anyone has put on a manual trim set up that would be up on the handlebars. I am wanting to do this on a 1996 spx.
It will be easier to get a good tested used one from Westside Powersports and just keep it original.
It's typically the lid gasket or boot on the rod outside the hull that fails and makes them go bad.
The only manual trim systems that I’ve seen work are the manual systems from the HX, but they aren’t at the handlebars. It works with a knob down by the pump nozzle.
