jeffbeckib
OK, so I buy this 98 sportster 1800, This is my first boat and I know nothing about motors and such. I know the port motor had some issue, and the owner told me he felt it was a rotary valve.
One motor runs fine, the other stalls when Idle, to start it up again I have to put it in fwd and give a little throttle, then she starts up, but still runs rough. Took it to Seadoo, they did a compression test and found the port side was reading 150/60, told me one cyl is bad and engine needs to be replaced. Also told me I'm missing the 2 flywheel covers and suggested I don't even put the boat in the water until I get those installed. So here's my concerns.
#1, Do I really need to replace the entire engine for 1 bad cyl?
#2, If I do, is there an aftermarket motor I can put in instead of Seadoo's $1,200 refurb rotax?
#3, What are the flywheel covers function? because if it's only function is to keep water off the fly wheel, that seems like it would be an impossible task since the entire bottom of the flywheel would be exposed.
Hope I don't sound like an idiot, even though I am one for having purchased a boat like this knowing nothing about them.
I got it for $2,500 and I'm hoping I don't have to put stupid money into getting it to run.
