Jet pump water leak, not the orifice
itsablast
Was wondering if this is normal to have a water stream coming from area to right of orifice. 2009 Seadoo GTI SE155. Engine is running at idle, water from hose is connected to flush connection. The orifice (yellow) is in good shape, the bilge venturi seals (white) are also in good shape. Seems to be good amount of water flow coming through exhaust outlet to right of jet. Picture is looking from the back of the jet at the flange. The Orifice is to the left (yellow) and the bilge venturi tubes are to the right. Spray appears to be coming from the bulge in the casting just to the right of the orifice seal. Any suggestions on this are appreciated.
thanks
I found out that the bulge in the casting is completely sealed. This must have been coming from the seal on the orifice (yellow). I was able to push the jet up slightly on the mounting studs and retighten. Now it seems to be all ok.
