Islandia Steering Cable nut size?
Scooter610
My steering cable nuts are loose, which needs a crow foot wrench. I can't tell what size it is. Any one know so I can get it tightened up?
Also, the rubber shaft boots are cracked, are they replaceable?
Thanks!
I seem to remember the hex size as 22mm. There should be a lock tab bent to a hex flat. If you feel the need to hammer on that nut, BE GENTLE! Those castings are not the strongest in the world.
The rubber bellows on the steering rod is a maintenance item to be replaced every year, as is the shifter bellows (moves the reverse bucket up and down.) They are 2 different part numbers. Not too bad to replace, IF you don't need to replace the cables.
