Is my Impeller toast
platinumtron
Had to replace carbon seal and wear ring so i figured i would go ahead and check everything else to include rebuild the pump. When i finally got the driveshaft out of the impeller i noticed some severe corrosion inside. To the point i think it may now be hollow once i remove the impeller from the impeller shaft(tool should be here tomorrow).
I would like to know, does this look serviceable or should i look for a replacement?
If serviceable, should i put an acid in the spline area to remove the corrosion and then pickle?
