Intake Grate
Rup
Greetings - what role does the INTAKE GRATE play in performance? Is there a GRATE that works better than others? My Seadoo is only on fresh water. Thanks
I haven't swapped one on, but from a performance stand point, an aftermarket intake grate is supposed to help the hookup on the water during turning and rough water, less cavitation. Someone can chime in on which aftermarket one is better than the other, but I'm sure any would be at least a slight improvement over stock.
You're cruising an LRV. Stick to the stock.. it's main function is to keep things from being sucked up into the pump.
