jammin777
hi guys, please view the pictures and let me know what you think. what you are looking for on the pump is one of the stater veins that has a small piece broken off. you can see the vein at the hub is curved and not straight across like the others.
also it is the side that faces the prop.
any chance of it being an issue? the impeller has a few small nicks and i think it should be ok. let me know if otherwise as i want 100 % efficienty. my main worry is the pump though. as you know, impeller exchange is cheap from sbt.
after reading the part number it is a factory impeller.
the wear ring is good 14 thousands clearance and with only a few hair line scratches.
and finally, i plan on pressure testing the pump, Ive read that you can use a mikuni pop off pressure tester but where can i get a screw in fitting for the cone filler that hooks up the the tester? and would a vacuum tester pump produce the same results? would i need to fill it with oil first for testing? thanks.
