How to Upgrade to the 2016 Sea-Doo Grips
seadoofeed
Upgrading to the 2016 Sea Doo Hand Grips. You will need ONLY the grips, no additional new parts are required. Left Grip: 277001958 Right Grip: 277001946 (both available at PWCMuscle.com here: 2016 Sea-Doo Grips) Using a small flat-head screwdriver pry out the end-cap of the grip. Using a 10mm socket, remove the retaining bolt. Grab the grip and pull it straight off the handle bar. You will now see there...
Read More...
