Rrm1387 Active Member Sep 27, 2015 #1 I thougth i would start a new. This is following my (just slowed down post) i need to pull the drive shaft .... Help....
red2blue New Member Sep 27, 2015 #2 Rrm1387 said: I thougth i would start a new. This is following my (just slowed down post) i need to pull the drive shaft .... Help.... Click to expand... If no one cuts you a link I can send you a pdf. Last edited by a moderator: Sep 27, 2015
Rrm1387 Active Member Sep 27, 2015 #3 I have been prying at it with no luck. Entire shaft keeps moving back and forth
red2blue New Member Sep 27, 2015 #4 Rrm1387 said: I have been prying at it with no luck. Entire shaft keeps moving back and forth Click to expand... You turn the driveshaft two full turns to the right....clockwise...before trying to pull it out? all c-clips? Got a drive shaft wrench?...adapter? Some find it easier to remove the clips with pump still in the boat. Last edited by a moderator: Sep 27, 2015
Rrm1387 Active Member Sep 27, 2015 #5 I either have to put pump back or block it. Is this right, you push the chrome ring towards the rear of the ski ,underneath is a clip. what does two turns to the right do?
red2blue New Member Sep 27, 2015 #6 you must unscrew the shaft from the hex ring. Prolly be better to get some help to hold the wrench while you turn the shaft at the tunnel.
