How to fit steering cable GSX800 1998
Hi guys does anyone know how to fit a new steering cable to a GSX800 1998model help needed
thanks
Alan:confused:
FIT??? Are you needing how to adjust it so steering / nozzel are aligned,
or Are you needing removal from the ski info?
Do you have a manual? For parts discription click on Seadoowarehouse:
http://partsfinder.onlinemicrofiche...oem/Seadoo_PWC.asp?Type=18&A=54&B=19&Action=O
To "fit" thru hull, Inside loosen the nut at hull, outside remove the stainless collar then two half nuts to pull cable into/thru the hull. You may need to also remove the Eye on cable end. Installation is reverse. Bill
