how to adjust trim manually? 96 xp
You can get the manual trim from an HX or a 96SPI and then it would adjust from the outside. Otherwise you can pull the two nuts that hold the electric motor and turn the plastic worm gear behind it. Normally you would want it just slightly higher then center and then put the motor back on just to hold it in place.
ok thanks i wanna make it angled up for some fun riding.
