On my 1997 GSX, if the Oil wasn't being pumped into the engine, does engine failure occur quite quickly? Is it a matter of minutes, hours or days? The reason why ask is that I've replaced my Oil filter recently and bled the system and their are no air bubbles in the 2 thin oil pipes, but that's no guaranetee that the pump is working? I know i could change the pipes (so i can see the oil initially moving) or even do the
pump test with the pump removed. I've taken the SEADOO out for a day since the service without any problems but for peace of mind is that enough time to determine that the oil pump is working?
Thanks for any comments
AW
AW
