how do you know when to rebuild a jet pump after you pull it?
FloridaLife
just for me to be more knowledagble
  • how do you know when to rebuild a jet pump after you pull it?
  • how do you know when you need to replace it with a new one?
Section 08 , subsection 03 of factory service manual shows the tolerances and whatnot to check.
General rule of thumb on wear ring is a dimes thickness test. If a dime can't fit Inbetween impeller and wear ring your are good to go.
Bearings, if they spin rough, drag, or growl it's time for replacement. Pump oil once per season can help lengthen bearing life.
Rob
Also, OSD Marine has the rebuild kit for each specific ski that you can buy. I recently had mine apart and looks to be ridiculously easy to rebuild. Not much to it.
