I have an 08 rxp255 that’s having some bad cavitation. Anything under under 20-30mph wide open throttle goes straight to the rev limiter. I’ve got the pump off and all looks good with .010 clearance on the wear ring and no gouges or anything. The ski doesn’t leak water into the hull so I don’t the carbon seal is causing it. The pump seal seems to be good but will replace it when putting everything back together. Is there anything I’m missing that could cause my issues?
