Hi All.
I have a 2006 GTX Ltd and the steering cable nut broke off and reverse was not working. I ordered two of the aluminum nuts as replacements. I figured I'd replace both the reverse cable nut AND the steering cable nut.
I am having a real problem. I thought I'd be done with this in an hour, but it's already been 5 hours and I have a weird problem on the reverse cable passageway.
Where the nut broke off, I now have some sort of spacer, shim tube or something weird that does not even have threads. Not only can I NOT get the remains of the broken nut out, even if I could, this metal shim/spacer is in the way. I don't know if some sort of protective tube that has been pushed out when the cable was moving or what it is, but this piece of metal is smooth with no threads and the nut won't even fit inside of it.
I have attached a pic of the opening where the new nut should be able to screw in, but as I said, this doesn't even have threads?
HELP Please ! Any ideas or suggestions ?
Thanks for any assistance.
