Help please. Cooling System - (White) 587 in a 96' xp 787 hull
I have a 1996 seadoo bombardier XP hull (717 motor came out) with a 587 engine from a 92 seadoo bombardier inside it.
The problem is The cooling system is not coming out the pea port in the back. I have only fired the seadoo up while hooked with a garden hose. But I've noticed the cooling system diagram for the 96 hull is different than the original 92 hull it came out from. Any ideas on what I should try?
I'll try to make a more detailed diagram of how I routed it. Thank you
You are going to have to plumb everything based on the 1992 engine diagram as the cooling systems are routed differently than the 720. Ignore the 720 diagram.
The issue comes in when you realize the(96' xp 717) Hull is designed around the plumbing based off the 717 motor. Which is different from the hull in which the 587 was pulled from (92' Bombardier) This is how I'm so confused.
Thanks for the reply
