Happy Fathers Day Guys! Need help!
Cythebudman
Just bought a 2006 GTX Limited 215 and it has a stalling problem at idle on occasion, when jumping or hitting choppy seas, and also when idling down from speed. It will usually rough idle until it kills. When I restart it though, it runs fine??? I thought it could be fouled plugs or bad gas, changed the plugs, ran sea foam through 2 tanks and tee problem is still consistent??? I was told the fuel pump was replaced and the problem remained, that's why I got a very good deal on the ski. Maybe improperly installed fuel pump/ seals?
The tip over switch. Tip switch. Probably loose and wrong position.
Or the Key connection DESS needs to be cleaned and make sure stays on tightly.
Checked fuel pump pressure, it's fine. Checked battery, noticed it was low. Checked voltage running and it was low. Hopefully it's just the rectifier and not the stator. Haven't looked into the tip over switch. Doubt that would let me get full throttle though.
