I was given this 97 GTX and shuttle craft by a friend. It had not run in 5 years. After several days of trouble shooting I replaced the MPEM, the batter and the starter solenoid. I bought the MPEM after extensive electrical testing and it is OEM and looks like new. On installation the ski turned over and eventually started up.
Ran it with a hose connection to see if it would start consistently and accelerate. Took it out on the water last Friday for the first test run. WOW, what a blast. I have no manuals or operating instructions for this unit and a few concerns:
1. When running with the hose attached the cooling system indicator hole beneath the stern eyelet streams water about 8-10 feet. On the water, only streams water about 1-3 feet at higher RPMs/Speed. Does not appear to be overheating, but concerned it is not circulating water adequately.
2. MPH on LCD display does not display MPH.
3. MPH gauge does not register MPH. (Hopefully these are not MPEM issues, assume there is some type of sensor pipe???
4. Have no starting instructions. To get the unit to turn over I have to push the start button til the red warning light flashes, then attach the DESS key and it will turn over and start. Is this normal?
5. Beeper / Buzzer does not work. It this a concern? Should I replace it?
Initially the ski would not accelerate, just bog down. At some point I went to start it and it blew a bunch of grass and what appears to be nesting materials out, and from that point forward, started immediately and accelerated normally. Assume the material came out the muffler / exhaust hose (unit was stored covered but outside for 4 years), should I remove the exhaust hose and check muffler for additional material?
Lastly, can these seats be reupholstered or do I just need to buy replacements?
Thanks Everyone!
James
Thanks Everyone!
James
