Fuel hoses?
billwalsh119
Anyone have a detailed diagram of where all the fuel lines and oil lines go to?
I just put a new motor in and I cant get fuel out of the lines even though the tank is half full! Does the system need to be pressurised or maybe I have a bad pump? How do I check?
Is it highly recomended to just block off the oil lines and use mix gas?
What ratio would you sugest running at?
its a 1996 XP 787.
THIS IS AN AWSOME SITE AND IM GLAD I FOUND IT!!
p.s im new to PWCs and cant wait to get mine running! Thanks in advance for all your help!
:cheers:
on the fuel pick up tube there should be marks for the nipples on tank
kinda hard to see, but they are there. vent ,return ,on ,reserve
they are marked vent ret on res
fuel valve has markings too, out, on, res
on and res from tank, go to fuel valve
vent from tank goes to hull vent line 'out board'
return from tank goes to fuel exit from carbs
out from fuel valve goes to fuel inlet on carb
bottom oil lines feed oil filter then the pump and right side crankcase
top oil tank line goes to left side crankcase
hope this helps, grap or download a manual
good luck 'mud
