airlar73
Ski is a 97 XP, and I've done the following:
-replaced solenoid (it was bad)
-changed out all fuel lines (no more grey)
-checked fuel selector, main and res both work fine
-cleaned fuel filter
-drained tank, filled with new gas
-rebuilt carbs with new needles and seats, internal carb filters, diaphrams and gaskets... used original springs
-blew through all check valves to ensure there were no clogs
-checked all fuses in the box (including the one that masquerades as a plug)
-installed new and correctly gapped plugs
-trimmed spark plug wires 1/4" (I'm getting great spark, so no issue there)
Everything is cranked down tight, so no air leaks, but I get two beeps (from the new buzzer) I can get it to fire if I choke it or if I squirt premix into the carbs, then it will run from anywhere from half a second to 5 seconds before dying. After it fires it will only give me the alarm tone if I hit the start button, so I am forced to pull the DESS key and put it back on to try to get it to fire again.
I have read every post relating to this that I could find and exhausted every possible option before posting.
Any ideas?
Any ideas?
