BigAl57
My Seadoo flooded while it was in the water and I couldn't get it started. We have a rocky shore and I couldn't get it up on the seadoo ramp on my own. Bilge was full. Once I got it on the ramp I found the original problem for not starting. I repaired the wire in the electrical box and then I took the plugs out and turned it over until the water stopped shooting out. There is a mist shooting out now. I have sprayed the cylinders with the seadoo fogging spray. Took cover and spark arrestor off carbs. I put a plug in and tried to turn it over. Almost but not quite. With both plugs in the engine almost doesn't turn over. With plugs out it tries no problem. The milky fluid on the plugs tells me there is still water in the crank case. Is it possible to get the oil out and replaced somehow without pulling the motor? I would have to tow the machine across the lake to get it on the trailer. I am guessing the difficulty with cranking the engine is because of the water. Any help is appreciated.
