Hey guys, I'm looking at a factory pipe setup off a 787 GSX, including all 3 exhaust pieces. Will this setup also bolt on to a 96 XP? Also, how can I tell if it's the spec 1 or spec 2 kit?
Hope your not paying over 300 cause I would send you one for that. If it has electronics and water injection then that is worth more. Be sure and get the exhaust support bracket because it is different then a stock one.
They are usually stamped on the machined surface that faces the gas tank. The Spec 2 is a couple mm larger internally and comes with a Factory Pipe manifold while the Spec 1 utilizes the stock manifold.
