Steve RXT 260 2011
Hi All
Hopefully someone has had the same problem and fixed or knows solution
Just bought RXP 260 2011 30hrs Engine warning light came on went into limp mode. Scenario
1) Fri Took out for first time little choppy 1/2 hour engine light came on into limp mode back to marina
2) Sat Took out went about 13km playing around no problem running great calm waters got up to about 92km engine light came on into limp mode, stopped engine reset Ok 10 min latter into limp mode stopped engine reset Ok 15 min then into limp mode.
3) Sun took out little choppy 20 min into limp mode , Stopped engine reset 15 min latter into limp mode
Took to Authorized Sea Doo dealer (560km away) They are saying that the pressure from Supercharger may not be providing enough or its out side calabration range for the throttle advancement or faulty sensor they are still looking at it.
To me seems like a sensor problem not necceary supercharger problem as it was running great when I had out on Sat for quite a while, The supercharger is very hot and takes time to cool down after use.
Has just been service 6 hours ago by authorised dealer Any Ideas
