Engine alignment tool
Hello. I have been rebuilding my 1995 gtx and know I will need an engine alignment tool to do it properly. The thing is I would rather not spend $200 on it. Do any of you guys know someone who would be willing to sell it to me for cheaper?
Nobody really sells it cheaper unless you find a used one. Sometimes people rent them out.
Check the for sale section here.
I would check Facebook marketplace and craigslist. Here in Michigan there is a guy who rents it out, maby someone near you will have one if your lucky.
Check OSD marine. They rent tools for a very reasonable price!
Hi.
I made one for my 4 tec jet boat for around $50.
Search the forum for DIY shaft alignment tool.
The way I made mine is I stuck different size sockets in the impeller until I found the size that fit snug, but went all the way into the splines. Then I measured this socket with calipers. For my 2006 Sportser this was 22mm. Then I measured my driveshaft length. Bought a 3' length of tool rod steel and a sleeve. Cut a short piece for the engine side and a long piece for the pump side. Bolt the pump in and there you have it! A DIY tool!
If you can slide the sleeve from one part onto the other then the alignment is good enough.
Hope this helps give you some ideas / options.
