Fvillar
Hello to all and thanks for your help
So I have this gtx and the problem is that the power is low
I have already done the full service to it oil new impeller housing new gas spark plugs and every thing but at wot flat water one rider max rpm 6000
Impeller is a 3 blades impeller 9/12
I have done tests with 3 sets of spark plugs and two sets of sparkplug coils
Compression test showed 148 to 150 in all 3 cilinders
Here a video of the motor running
https://youtu.be/9SS8iczzoic
Also the report from my candoo pro
When I started it out of the water the smell of the exhaust itches very bad in my nose
And when running it in the water noticed white smoke coming out of the exhaust
Coolant color is normal and oil is ok no milki look on any of the 2
I think the white smoke is in burned gas
What would you recommend me to do next
Again thanks for your help View attachment Report1.pdf
