onlyadoo
1996 GTX 787
Put the key on and no beeps, sometimes a faint beep, however always cranks over. Sometimes few a split seconds and hard stop, it will continue this way until you remove the key. Other times you put the key on, same beep situation but it will crank smoothly all day, gets everything but spark, will continue this way until you remove the key. Other times you put the key on and it fires right up, first try, no choke needed, however idles strong, however sounds like it has a bit more rumble to the exhaust, and when you take off it revs up to about 6500 rpm and then Boggs hard to like 2500 rpm and back up and back down and so forth. I feel like it's electrical, but maybe a combination of multiple issues. Bad post? Bad ground? Bad coil? I did pull the red wire and swap rectifiers, swapped mpem's. PO had new fuel lines, fuel selector and carbs rebuilt. Went through them anyway, carbs had a gasket missing, replaced it. Fuel selector was clogged, and think it's because it was a cheap knock off. Couldn't blow through it and nothing was inside, replaced it. It wouldn't rev as high or even come out of the hole prior to these two changes. Any Ideas?
