B Boyd12 Active Member May 9, 2020 #1 The SD manual states to adjust the oil pump using the "longest mark on the lever". Since BOTH marks are the same, which should I use?
mikidymac Moderator Staff member Moderator May 9, 2020 #2 The book looks like they are using the mark to the right to align.
B Boyd12 Active Member May 9, 2020 #3 That is where I set it. I think that will supply more oil than the mark to the left. better safe than sorry
mikidymac Moderator Staff member Moderator May 9, 2020 #4 Yes, if anything a little more oil is fine.
