Dead 2003 GTX RFI
fauntlaroy
Hi All,
I have a 2003 GTX RFI and I’m having some problems I’m hoping someone can help me with. I tool the ski out today, it started fine but didn't sound as smooth as it normally does. I cut the engine and as I did I noticed the "hi-temp" message on the dash. The engine then cut out. Now when I attach the key I get nothing… no beeps, no lights… nothing. Does anyone have any suggestions what could be causing this problem?
Cheers
Dave
Start by checking the Battery, then compression. Determine either an Electrical
or a Mechanical issue, as one can and will effect the other.
also check all electrical connections
most important the ones to the main brain, mpem
look for corrosion
good luck '
mud
