Chrille
Hi.
were is it located?
if the engine wont start can that be the problem?
I once moved the throttle shaft arm by hand and the engine started up. if the position of the shaft arms is wrong should the engine start?
i moved the boat by trailer and since then it is dead. i found a couple of loose stopscrews. spark advance screw, idle stop screw and so on.
Can i check the timing without any instruments?
Once again a thousand questions.
//Chrille
were is it located?
//Chrille
