Doctor_Venkman Member Mar 11, 2018 #1 Looks like my GTI is a little low on coolant. Is there a particular brand or type that I need to add or will any off-the-shelf coolant be good?
Goingpwc Member Mar 13, 2018 #3 The coolant needs to be ethylene-glycol. Antifreeze should be changed every other year. There is a nice Youtube on how to change the antifreeze. I hope this helps.
Doctor_Venkman Member Mar 13, 2018 #4 Thanks. I thought that was the case, but the manual says not to mix.
S seadoon1 Member Mar 18, 2018 #5 Doctor_Venkman said: Looks like my GTI is a little low on coolant. Is there a particular brand or type that I need to add or will any off-the-shelf coolant be good? Click to expand... Be sure to check weep hole. It may be leaking there, which means new water pump seal needed. My two 2014's needed a new seal at 100 hours! Both.
Doctor_Venkman Member Mar 19, 2018 #6 seadoon1 said: Be sure to check weep hole. It may be leaking there, which means new water pump seal needed. My two 2014's needed a new seal at 100 hours! Both. Click to expand... OK. I'll admit that I have no idea where the weep hole is.
S seadoon1 Member Mar 19, 2018 #7 Doctor_Venkman said: OK. I'll admit that I have no idea where the weep hole is. Click to expand... Attachments 2 Weep hole2.jpg 1.5 MB · Views: 39 Water pump seal.jpeg 165.4 KB · Views: 37
