I have read on other posts that on a gsx the compression should be around 150 on both cylinders. I am getting a reading of 122 and 120. Could part of my problem be carbon build up on the piston head? Also I posted water coming from the head. Found out the o ring was ok it just had alot of corrosion. So i cleaned the o rings and lubed them with marine grease. Seems to have fixed the problem. Weird engine noise is gone. (I would give it gas and it would not idle down). If I am unable to see any damage on the o rings could they still be the low compression problem? Any help is greatly appreciated. Also found a small hole in my water box rave valve. Can this be fixed or should I order a new diaphragm? If so any ideas on the best deals?
