HI: newbie here; I just replaced the shaft bearings and seals. When I looked at the impeller it a had a few nicks but nothing strange or large. The rubber ring did have 1 (one) pencil lead width grove 3/4 way around the ring. THe ring and impeller where very tight.Difficult to turn with out soapy water for lubrication. Just seemed nice and snug.Put it all back together and ran fine for 1 day. Now full throttle coming out of the hole the RPM goes from 4k right to 7k and no thrust.Just cavitation like you would get from an outboard prop that was pushing air instead of water. IF I go slow it seems to be fine.If i then go full throttle or get in 8-10" chop I get reduced thrust.The grate is clear. IF the ring was real tight I can't understand the cavitation. I did suck in some lilly pads, before this seemed to be a problem. Could stuff like that bend the impeller? I'm at a total loss. Every thing seemed fine when it went back together.If I pulled the nozzle assembly what would I look for ?
Thanks for any suggestions.
